That’s why snow removal safety tips are more than helpful they can make the difference between a safe winter and an injury-prone one. Whether you’re shoveling snow and shovel by hand or using a high-tech solution like the Yarbo Snow Blower, following the right precautions is critical.
1. Assess and Prepare Before You Start Snow Removal
Check the Conditions
Clear the Area
2. Dress and Warm Up for Winter Work
3. Safe Manual Snow Shoveling Techniques
4. Using Powered Equipment Safely — Yarbo Snow Blower
Learn the Manual and Controls
Triple-Layer Safety System
Radar — helps detect obstacles ahead.
Three cameras — for side and front view to identify objects and terrain.
Bumper protection — to absorb impact and stop the robot if needed.
Safe Auger Operation
Never work on the auger while it's running. Always press Stop on the rear or use the app to shut down the system.
Avoid touching or clearing any debris from the auger until you’re certain it's stopped and powered down.
Make sure the protection fence (auger guard) is securely installed before starting. It’s designed to keep your hands and feet safe.
Avoid wearing loose clothing, scarves, or anything that could get caught in the auger.
Use the “No-Go Zones” feature in the app to prevent Yarbo from going near large obstacles.
5. Regular Maintenance to Avoid Winter Failures
Pre- and Post-Operation Checks
Make sure the discharge chute is clear. Operating with a clogged chute can damage the motor or reduce clearing performance.
Remove snow buildup from the robot’s body, especially from the tracks, and wear gloves to avoid frostbite.
Inspect the auger, impeller, shear pins, and skid shoes for wear or damage. Replace worn parts promptly.
Lubrication to Prevent Freezing
Battery Safety
Turn Yarbo off properly via the app.
Remove the battery pack by unscrewing anti-theft bolts.
Clean or inspect battery regularly; store it safely when not in use.
Cleaning Tools
Bonus Tip: Dealing with Wet or Packed Snow Safely
Use medium movement speed in the app when working in wet snow. Yarbo’s dynamic adjustment algorithm manages current load to prevent strain.
If you have the plow blade accessory, attach it for better performance on wet or packed snow.
Regularly clear the chute and apply non-stick spray (or similar) to the auger, impeller, and chute to reduce build-up.
If the chute clogs, press Emergency Stop to power down first, then use the clean-out tool to remove snow safely.
Why Robotic Removal with Yarbo Is Safer Than Manual Shoveling
Less physical strain: No heavy lifting, pushing, or constant bending.
Reduced injury risk: Your heart and muscles don’t bear the same load as manual shoveling.
Autonomous operation: You can schedule runs via the app cold, icy mornings don’t always mean you have to go out yourself.
Advanced safety features: Radar, cameras, bumper all work together to detect obstacles and prevent accidents.
Self-recharging: Yarbo docks and recharges automatically, so it stays ready without manual intervention.
Common Hazards and Yarbo-Specific Solutions
| Hazard | Yarbo-Aware Solution |
| Frozen Tracks | Clean tracks post-session, lubricate regularly, and thaw safely if frozen. |
| Auger Injury | Always power off before approaching, use the auger guard, and avoid loose clothing. |
| Docking / Charging Errors | Use correct mapping, set no-go zones, and follow app instructions. (Some users report routing issues; proper setup helps.) |
| Sharp Objects / Obstacles | Use the no-go zone feature, and avoid letting Yarbo run near fragile or dangerous obstacles. |
| Surface Damage | Some users removed anti-slip studs on tracks because they were scratching concrete. |
A: Yarbo’s autonomous operation eliminates much of the physical strain of manual snow removal. Its triple-layer safety system (radar, cameras, bumper) helps avoid collisions, and the need to manually refuel is removed reducing risk of accidents.
A: Yes — in the Yarbo app, under Work Plan → Modify → Pathway → Settings, you can change the auger angle. But always power off Yarbo before doing any physical adjustments to reduce risk.
A: Use a medium speed setting, apply a non-stick spray on the auger and chute, and clear out solid snow frequently using Yarbo’s clean-out tool. Also, the plow blade accessory helps when snow is too wet or heavy. Or simply use Yarbo snow shovel attachment in advance.
A: Move it to a warmer place (like a garage) to thaw naturally, avoid direct heat, and then lubricate tracks with grease after thawing to help prevent recurrence.
A: No,never reach into the chute while the auger is spinning. Always use the Stop button on the unit or app, let it fully power down, then use the provided clean-out tool.
A: Pre- and post-run checks include clearing the discharge chute, examining the auger and skid shoes, wiping snow off the body and camera lenses, and inspecting the battery. Also, lubricate the tracks regularly.
